Hyperx Fury Problems
Solved by -rascal-,
11 hours ago, Dantoshou said:This is it today with 2666 in single channel and 2400 in dual channel, shows as 2667.
I also don't get why even with 24GB installed it says only 16GB is being utilized by the system, is it that it's being reserved by hardware and why would that be the case?
Hardware Reserved issue should be separate from the 2666 / 2400 MHz reading.
From your previous screenshots, when you had just 16GB installed, it only showed a few MB for Hardware Reserved -- which is normal.
There are a few places you can check...let's start things off easy first...
Go back into BIOS and make sure ALL 24 GB is recognized.
- If all 24 GB is showing up, proceed to Step 2
If only 16 GB is showing up, re-seat the RAM sticks.
Load into Windows, and run something like CPU-Z, and check the Memory and SPD tabs to make sure all 24 GB is showing up there.
Go into System Configuration (You can use the Windows 10 search bar) >> Boot >> Advanced Options. Make sure the 'Maximum Memory' box is NOT checked.
- You may need to reboot your system.
