FAN for push pull
Go to solution Solved by Samacle,
http://www.pccasegear.com/index.php?main_page=product_info&products_id=17913&cPath=510
How would 2 of these fans, going to do with a push pull config on a Hyper 212 EVO, taking into consideration silence and performance. I was hoping to buy these 2 fans soon. Thanks in advance! :D
I can vouch for their quietness, got one on the back of my 212 plus with the stock fan, temps are pretty good as well.
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/98107-fan-for-push-pull/
https://linustechtips.com/topic/98107-fan-for-push-pull/#findComment-1313727
Awesome! How is the noise at full speed?
https://linustechtips.com/topic/98107-fan-for-push-pull/#findComment-1316096
Can't hear it over my other fans so I can't really say, it won't be that loud though
Alright thanks bud :D I am going for a completely silent build, so just wanted to make sure
https://linustechtips.com/topic/98107-fan-for-push-pull/#findComment-1316168
Make sure to tell us how it goes :)
Certainly :D
https://linustechtips.com/topic/98107-fan-for-push-pull/#findComment-1316598
