what the heck...your problem is poorly described bro.
Let me get this straight, when you turn your computer on with usb device attached to the front USB port, the two front USB port do not function. meaning that your already connected USB does not function. However, if nothing is plugged in, and you turn your computer on, the two ports work?
CPU: 8600k @4.9  (1.39v) |  Cooler: NH-U14s | Mobo: Asus Strix z390i | Ram: Gskill DDR4 Trident Z 3600 8GB x 2 16-16-16-36
GPU: Gigabyte G1 1080 GTX | Case: Prodigy ITX | Fans: NH-A14, (exhaust) NH-A12, (intake) NH-A20 (intake)
Samsung EVO 1tb | Samsung EVO 512gb x2 | Intel ssd 128gb
PSU: Powerstation 500W
https://linustechtips.com/topic/980851-front-usb-port-issue/#findComment-11836314
My bad, I tried to make it too simple I guess.
For example: if I have my phone plugged into one of my front USB ports and then turn on my computer, it does not charge or send any power to my phone. However, if I turn on my computer, wait for it to fully turn on, and then plug in my phone, my phone will charge.
This doesn't just happen with my phone, that was just an example. This has happened with every single thing I have plugged into those ports.
https://linustechtips.com/topic/980851-front-usb-port-issue/#findComment-11837902
Go into bios and check your setting for usb always on
https://linustechtips.com/topic/980851-front-usb-port-issue/#findComment-11841379
