Hey guys I heard of SMART and decided it would be a good idea to look at all of my hdd's data, this is given for my 500gb seagate barracuda.
My question is what do I look for in smart data and is the "fail" on the ecc error rate a problem?
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
https://linustechtips.com/topic/98067-reading-smart-data/
crystal disc info will help you, listen to what that says, its the best software by far for hdds.
Listen if you care.
https://linustechtips.com/topic/98067-reading-smart-data/#findComment-1311694
listen to what it says!
6029dac29d801c9c90046fe7099a7a2e72e9112c
Grammar nazis are people too!
Treat your local grammar nazi nicely and he might teach you a thing or two. (Note that I'm Belgian and not a native English speaker.)
Chivalry isn't dead!
https://linustechtips.com/topic/98067-reading-smart-data/#findComment-1311736
any current value near the threshold is a bad sign when it comes to smart data but thats not true of certain ones like temperature and airflow
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/98067-reading-smart-data/#findComment-1311794
Would you therefore suggest I return this hdd?
https://linustechtips.com/topic/98067-reading-smart-data/#findComment-1311936
i would say yes your ECC error rate failed it could be a point in failure if you can wipe it and return it for a new one why not?
https://linustechtips.com/topic/98067-reading-smart-data/#findComment-1312061
