UPS question
Solved by BrinkGG,
6 minutes ago, imshadowfox said:Heyo,
I don't know how to shop for UPS' but is this good enough to keep my system running long enough to do a proper shutdown (5-10 minutes or longer ideally):
System specs (including 2 monitors that are not listed):
Should be good enough for almost half an hour at medium load to be honest.
Depends on your overclocks though. Those can cause a lot more power draw then normal.
Even at max load from your system, you should get at LEAST 10 minutes. so yes that should be enough time to shut it down properly.
