linux Changing structure of partitions on drive without affecting Linux installation
Solved by Guest,
You got EFI installed. Basically grub is installed into the EFI system partiton, unless you delete it there is no change for breaking grub.
I would however suggest you to chroot into the only Linux distro you like, then running again grub-install and update-grub just for clearing others grub entries
This requires (In case you are on a USB live)
- mount /dev/sdaX /mnt where sdaX is your Linux install you wish to keep
- mount -t proc proc /mnt/proc
- mount --rbind /sys /mnt/sys
- mount --rbind /dev /mnt/dev
- chroot /mnt
- mount /dev/sdaY /boot/efi where sdaY is your fat32 efi partition
Then do, grub-install
then update-grub (or grub-mkconfig -o /boot/grub/grub.cfg)
You may want to re-run update-grub into your working linux system if you don't find all the grub entries (like Windows)
