What cooler are you using? What case are you using and where is the cooler mounted?
Where are you shopping / located? Budget?
https://linustechtips.com/topic/980592-best-fan/#findComment-11833669
my cpu cooler is Asetek 591LX 360mm High Performance CPU Cooler - 20xx
my case is Corsair Graphite 760T V2 Full Tower Case - Black
ive got my cpu cooler mounted on the top of the case
im located in England
my budget is around £10 per fan, a pack of 2 would be ideal as it would work out cheaper,
thanks.
https://linustechtips.com/topic/980592-best-fan/#findComment-11833775
Why 2 fans for a 360mm rad?
https://linustechtips.com/topic/980592-best-fan/#findComment-11833789
Just now, Lewis131 said:
i have 5 fans on there already, looking to put another one on and put another fan in the case, sorry was not very descriptive when i made this post
So a single red fan on the rad and another fan for a rear case exhaust?
What fans are you currently using?
https://linustechtips.com/topic/980592-best-fan/#findComment-11833807
i have 5 fans on the cpu cooler its self, then 2 at the front pulling air in and one at the back bring air out, the 5 fans on the top are taking air out.
https://linustechtips.com/topic/980592-best-fan/#findComment-11833812
I was asking for the model names of the fans currently being used.
Where are you using the 2 new fans?
https://linustechtips.com/topic/980592-best-fan/#findComment-11833817
oh sorry, i have 2 corsair af120 120mm fans on the cpu cooler, and the rest on the cpu cooler are ones that came with the cpu cooler, the 2 in the front are ones that came in the case, same for the 140mm one in the back of the case.
https://linustechtips.com/topic/980592-best-fan/#findComment-11833827
If you're using the stock cooler fans in push and AF120's in pull, you can get a twin pack of matching fans for the same aesthetic.
https://uk.pcpartpicker.com/product/hbbp99/corsair-case-fan-co9050002ww
If you want to use the stock cooler fans in pull, Magma Advances would be a bit better: https://uk.pcpartpicker.com/product/kFBv6h/enermax-case-fan-ucmaa12a
https://linustechtips.com/topic/980592-best-fan/#findComment-11833868
what about something like this https://www.amazon.co.uk/Corsair-AF120-LED-Quiet-High-Airflow/dp/B00F6S0XJO/ref=sr_1_1?ie=UTF8&qid=1539022960&sr=8-1&keywords=corsair+fan+red
https://linustechtips.com/topic/980592-best-fan/#findComment-11833892
It's not as good as the original ringed AF120 QE's but they perform fine and would match better if those are the fans you already have.
https://linustechtips.com/topic/980592-best-fan/#findComment-11833898
ok ill probably go with https://uk.pcpartpicker.com/product/hbbp99/corsair-case-fan-co9050002ww as they are better then
thanks
https://linustechtips.com/topic/980592-best-fan/#findComment-11833903
