Recommend cooler for small form factor case
Hi guys
Currently got the below pc setup where CPU is hitting 90c on stock speeds and stock sleath cooler which I think is too hot. Have 2 X 120mm fans at the front as intake. And 1 X 80mm exhaust at the back and 1 X 120mm at the side as exhaust.
Amd Ryzen 5 2400g.
Asus Prime B450
8gb patriot viper 3000mhz (2 X 4gb)
Sapphire rx570 pulse ITx this runs max 65c
https://www.ebuyer.com/724862-avp-hyperion-ev33b-black-cube-case-cas-107
Can you recommend a cooler that would fit in my case. I was tempted to go cooler master 120 light water cooling and mount the radiator on the side of the case. Possible as an extra fan to radiator for push pull config. Budget is fairly flexible but don't really want to spend much more than £30.00
https://linustechtips.com/topic/979080-recommend-cooler-for-small-form-factor-case/
10 hours ago, Mello said:
Ty @Mello
10 hours ago, leegarnham87 said:
Hi guys
Amd Ryzen 5 2400g.
Asus Prime B450
I would go with an AIO in the front exhausting rotation so it pushes air out. so your air intake is from the side.
Also aio option I was there noting of added another 120mm fan onto it as I have one high performance one spair that's also Pwm with an adapter to slit the connection
Cooler Master MasterLiquid Lite 120 CPU Liquid Cooler '120mm Radiator, 1x MasterFan Pro 120 AB PWM Fan, White LED' MLW-D12M-A20PW-R1 https://www.amazon.co.uk/dp/B06WRRDS73/ref=cm_sw_r_cp_apa_VnBTBb82MKPXK
The 80mm at the back of the case is an intake. Flip it to exhaust instead and see if that helps. What are your temps with the side panel removed?
Heya sorry pic slightly old. This is set as an exhaust already
Builds:
Have you tried checking the thermal paste spread and reseating the stock cooler?
I think the key answer I am looking for us to reduce my cpu temps via a different cooling solution
So need a new CPU cooler that would fit in the case
Fan slot wise. I have 2 X 120mm at the front. ,120mm at the side and 80mm at the back. All the 120mm fans are the same
I don't the no it's a case issue as GPU is fairly cool
Use an All In One cpu cooler. a 240mm cooler should be a nice fit in front and the fan should be exhausting outside not inside.
Is this
Cooler Master MasterLiquid Lite 240 Liquid CPU Cooler "240mm Radiator, 2 x MasterFan Air Balance 120 Fans, Dual-Chamber Pump" MLW-D24M-A20PW-R1 https://www.amazon.co.uk/dp/B0763PS24T/ref=cm_sw_r_cp_apa_.iCTBbPVDJKSV
Do you think it would fit
So 240 radiator at front and the side and rear fan as Intakes.
I assume cooler masters series as okay for the prices
yup that will still give you great airflow and keep your cpu temps close to ambient temps.
Any slim form radiator is your best bet doesnt matter if its from cooler master or who ever. just check the pump model. Higher the better.
