CPU temps @ 80C while gaming
8 minutes ago, ElfXD said:yo my bad I rushed that and typed quickly because I just remembered, I had things to do during the moment.
CPU - i7-8700k
Cooler - Coolermaster Hyper 212 Evo
as for the overclock, there was a feature my motherboard (gigabyte) BIOS with the "CPU upgrade" option the naming is stupid but its just basically overclock presets and have "i7 8700k 4.8GHz" option.
edit: i7-8700k's TDP is 95c, so as long as it remains in the 80s I should be good?
You should be fine with temps with a TDP of 95C. The motherboard might not be doing the most efficent overclock, its likely just pre-configured based on some presets and not very indicative of what you need. For example you might have a golden chip that overclocks excellent with lower voltage, but that preset doesn't account for that and will just pump whatever voltage they think necessary to keep 4.8ghz. Although great for normal use, the 212 evo isn't going to hold up to very high overclocks and high voltages, it just doesn't have the cooling capacity.
