hyper-v port forwarding?
Go to solution Solved by Brian Furious,
You mean you want to port forward an hyper-v VM :P
Well, maybe first bridge the connection with your curren LAN segment, the you just port forward it from your router/firewall like any other normal device
3 hours ago, unijab said:
hyper-v is for virtualization... port forwarding is done with networking equipment (virtual and physical )
If there's a Nat layer between your physical and virtual environment you'd also have to do this, although would generally be poor practice outside one or two corner cases
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/978947-hyper-v-port-forwarding/#findComment-11818296
