Personally I would suggest upgrading to new headphones, you'll see the biggest difference from that. If you can, try some out. Presumably you like open headphones, so i'll list a few highly regarded cans that would be a good step up. I'm not sure if all of these are within budget though, i'm used to UK prices. But if you can get a good deal and sell your old HD555s, it's probably doable.
Beyerdynamic Dt880
AKG K701/702
Audio Technica ATH-AD900
Grado SR325i
Sennheiser HD600
https://linustechtips.com/topic/97891-audio-hardware-upgrade/#findComment-1309560
Beyerdynamic Dt880
AKG K701/702
Grado SR325i
Sennheiser HD600
While all solid suggestions, the DT880's are the ones that would work best with his soundcard, since his soundcard has such a high output impedance.
https://linustechtips.com/topic/97891-audio-hardware-upgrade/#findComment-1309579
You're running a pretty good setup. The STX is a pretty good product overall and has very good value for money.  The next upgrade from that would reach around $400-700 for a DAC+Amp.
If you really wanted to upgrade your setup it would be better to upgrade your headphones as they'd give the most value for money. Source and Amp upgrades have really high diminishing returns
https://linustechtips.com/topic/97891-audio-hardware-upgrade/#findComment-1309600
Hmmmmm.
Sponsored by Twitch and DxRacer.
https://linustechtips.com/topic/97891-audio-hardware-upgrade/#findComment-1309621
https://linustechtips.com/topic/97891-audio-hardware-upgrade/#findComment-1309630
