It depends entirely on what you're doing
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/978868-does-ram-speed-matter/#findComment-11816798
6 minutes ago, ImInHugeTrouble said:
Hi, I was wondering if ram speed matters? Should I go for 1333 mhz or 1866 mhz ddr3 ecc ram?
yes it does matter. not a lot in gaming so much as encoding and number crunching it matters. are you ddr3 or ddr4? max of ddr3 is around 2400-2600 if you can find the higher speeds you pay high price. I got a 4x8GB kit of corsair and was told by the dev team there that all sticks above 2000Mhz are basically the same. I paid almost 380USD for the 32GB kit but have seen huge improvement over the 1600 kit and the 1866 kits I have in hand
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/978868-does-ram-speed-matter/#findComment-11816807
For ddr3 it is very small performance gain.
https://linustechtips.com/topic/978868-does-ram-speed-matter/#findComment-11816853
