Sapphire RX 580 Nitro+ fitting question
Go to solution Solved by TVwazhere,
2 minutes ago, phil7990 said:
Hi, I have an aerocool GT-A and wanted to know before I buy, does the Sapphire RX580 Nitro+ card fit in in my case? The MSI GTX770 twinfrozr 2gb, did fit. However, the connecting cabels were also at the sight and it had just about enough room. I hope this card does fit. Really want it!
It will fit
It it can fit cards like these, it will for sure fit
https://pcpartpicker.com/b/YJpG3C
https://pcpartpicker.com/b/zmP323
Hi, I have an aerocool GT-A and wanted to know before I buy, does the Sapphire RX580 Nitro+ card fit in in my case? The MSI GTX770 twinfrozr 2gb, did fit. However, the connecting cabels were also at the sight and it had just about enough room. I hope this card does fit. Really want it! Also, what about the Airflow? I have 2 topfans, 1 backfan and 1 frontfan.
https://linustechtips.com/topic/978438-sapphire-rx-580-nitro-fitting-question/
It will fit
4 minutes ago, TVwazhere said:
It will fit
Nice, your comment is excacly what I needed. No airflowproblems as well. Have 2 topfans so. Guess this case will survive. Mine did fell off of a table though (due to having big cats) :( but nothing inside was broken. Only some of the frontpannels closing pieces are broken as well as a closing piece of the dustfilter at the front. Put it in a much more stable place after that. It still works fine now.
Anyway, thanks for answering!
