Ok so it's getting abit grimey now, what's the best way to clean a mech keyboard? If I pull all the caps off I'm worried about damaging the LEDs when I clean it. .  .Obviously should get some q tips and rubbing alcohol, but any thing else I should know?
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/97843-cleaning-k70/
I have a k70 and It was hairy as F*ck. I removed all the keys with the key cap puller that came with the keyboard. Just took some ear cleaner stick things and took away all the dust and stuff. No need to worry about the LED's unless you put a ton of pressure on them.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1308811
Btw ripster has some nice guides about keyboards. Google ripster keyboard guide.
Selling my parts of my 900D rig for a jacked up Ncase M1. PM me for offers if interested (will take some reasonable-low offers because I'm desperate).
Parts that I'm selling: 900D (1 slot cover broken for stealth DVD drive mod) | Asus Z87 Deluxe | Cooler Master 212 Evo | Corsair 4x2GB black ram @1600mhz | EVGA 1000G2 PSU (2 cables with missing heat shrink) | DVD drive | HP membrane keyboard | Ducky Shine 3 YOTS in blue switches (warranty sticker broken)
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1308848
The K70 comes with a keycap remover.
I know I'm saying that the one that comes with it isn't really the best and can be dangerous...
But when used properly is fine,cause I happen to have one and I broke a keycap on my kb since it squishes the caps horizontally.
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1309044
Hey Logic,
I have a k65 and I just use an air compressor. It is unnerving as hell ripping those caps off though!
If you're using a cleaning solution, just let it air dry for a few minutes before powering it back on. Hair drying might come in handy.
8320 @ 4.3ghz l Gigabyte 970a Ud3 l Hyper 212 Evo l R9 290 l 8gb RAM 1866 Vengeance l 1tb WD Black l 120gb Samsung Evo SSD l HX750 Gold PSU l 500d Arctic Case l Windows 8 OS l K65 and Blackwidow Keyboard l M65 and DeathAdder 2013 l Qck Steelseries l 24in Vizio Monitor 1080p
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1309076
Just a tip don't yank off the keycaps especially since you PROBABLY don't have the wire puller keycap remover or whatever it's called.
Just saying cause it's happened to me :P
yeah I have the remover. . . was more worried about damaging the LEDs from cleaning than removing, ok thanks I'll get some compressed air monday :)
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1309144
you can melt a custom tip for your canned air thats flatter turn upside down (not the canned air the keyboard) and spray till you get freezerburn. I got this technique from modding shaving cream tips for halloween. anyone know what im talking about? I grew up in NY
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1309285
I recently cleaned my k70 and found a few things:
*Try to go with the brushed aluminium if using a cloth or bud that is easily degradable like a cotton bud, the grain of the metal is rough enough to pull them apart easily and it leaves behind more lint that before you started
*The corners of the cherry keys are quite sharp so will mess up your cloth fairly easily so try to avoid hitting the corners
For me personally I used cotton tips with a small amount of rubbing alcohol just to break through a few dried up spills that were on my board and also pick up dust more easily!
Have fun cleaning your board and I hope it doesnt got too badly ;)
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1309769
Although my K70 MX Red's is only a week and a half old to me, I make a habit of using compressed air on it at least twice a day, mainly because I got two cats in the house and there is hair in the air and dust and particles that I notice land on the keyboard during the day, even when i'm not using it. If you get compressed air and make the habit of doing a good blow to the keyboard twice a day or so, you probably won't have to do a full cleaning in a long time.
| Specs: Red = New | CPU: AMD FX 8350 8-CORE 4.2ghz | MOBO: ASUS Crosshair V Formula-Z | RAM: G-Skill 16GB DDR3 SDRAM | GPU: EVGA Geforce GTX 780 Ti | CASE: Antec 1200 Full Tower | KEYBOARD: Corsair K70 Black/Red Cherry MX Red's | MOUSE: Corsair Raptor M40 |
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1315961
Before you finally log off, I recommend you cover your KB with something like a large lint free cloth(I'm not sure if it being lint free will do anything lol) or maybe a plastic cover that came with your KB or something.
I got a clear cover included with my ducky even though I don't cover my keyboard cuz I'm too lazy to bring it out. Some ideas I came up with
https://linustechtips.com/topic/97843-cleaning-k70/#findComment-1316082
