So I have just bought a new PC, and need new monitors as mine are extremely old and in dire need an upgrade to compliment my new build, Looking to run dual 27" 1440p
Here are my two choices:
ASUS ROG SWIFT PG278QR 27"
or
Dell S2716DG
The asus monitor is available in store local to me but for a higher price
Dell monitor I would need to order online but currently discounted and over 200$ cheaper.
https://linustechtips.com/topic/978278-need-help-choosing/
20 hours ago, Veramos said:
Dell S2716DG
I own this Dell and I have zero regrets. I very rarely experience any issues whatsoever with it. Stuttering/lag just doesn't exist on this 1ms monitor. I paid $429 for it after two price match guarantees during the summer. Totally worth it. No clue why I would ever need two of these monitors though. I also very rarely use the G-Sync because I just cap my frames using MSI Afterburner with v-sync OFF if I want to play games using a locked frame rate. I usually lock my fps at 90 because my CPU is only an i5.
https://linustechtips.com/topic/978278-need-help-choosing/#findComment-11813922
