So, I wanted to take security more seriously and hence wanted an AV for my system.
My friend told me this is what he does:
1. Run Malwarebytes
2. Run AdwCleaner by Malwarebytes
3. Run HitmanPro
4. Run Anti-Rootkit by Malwarebytes
So, I started doing the same. I ran Malwarebytes and it detected a few "Unwanted files" and I cleaned them.
Then, AdwCleaner did its thing and said the system needs to restart. So, I did it.
But then, as soon as it started it started behaving oddly. Boot times were much longer, I had to input the password 2-3 times before "Welcome" (It didn't even show 'Wrong password') and then as soon as I got in, Windows said "Your PC will restart in one minute. Close this window and save all you r work." and it has been doing this ever since. I have attached the AdwCleaner log file for reference. It has a list of the deleted files, few of which are Registry files.
I was able to get into startup repair screen and here's what I have tried so far:
1. System Restore to previous point. - there were no points to restore
2. Going back to previous version of Windows - Failed
3. Running automatic Startup Repair - No luck
4. The command sfc /scannow (System file check) - No errors detected
5. The #2 of this guide.
6. Ofcourse, I removed the AdwCleaner.exe by booting into Safe Mode.
7. Tried the Ccleaner registry cleaning tool.
System Reset is the last thing I want to do.
Thanks for reading. Any help will be REALLY appreciated.
AdwCleaner[S00].txt
https://linustechtips.com/topic/978159-pc-stuck-in-a-restart-loop/
boot from the same build of W10 from a USB drive and try repairing, if that doesnt work you might have to reinstall windows.
