Help with 1TB HDD
Go to solution Solved by Pickles von Brine,
Doesn't matter. Hard drives have a max transfer of around 100MB/s. So even if you were running SATA 1 you wouldn't be able to max out the connection. SATA 2 for any hard drive will pose no issues whatsoever. Just use it as you normally would.
Now, for a 5400RPM drive, the data access speeds will be slower and the data transfer speeds may be a bit slower but it shouldn't be too bad. 7200RPM drives do run faster and have better access times though. Just play it by ear and see what happens. My philosophy is if works it works.
 So I just made a gaming computer for the first time my actual hard drive for that is 120 GB SSD and I want to put my programs and games on another hard drive I have a 1 TB 2.5 seagate ST1000LM024 5400 RPM SATA 2 not 3.  I understand the RPM is low rather have a 7200 RPM and SATA 3.   With that work for now till I get money for a 3.5" 2 TB hard drive and doesn't make any difference if I get a 2.5"or 3.5"?
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/977857-help-with-1tb-hdd/
My PC:
My Kids PC:
https://linustechtips.com/topic/977857-help-with-1tb-hdd/#findComment-11806896
You can use a 2.5" drive if you like, there's no problem with that. And 5400RPM isn't slow (it's 3/4 the speed of 7200RPM).
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/977857-help-with-1tb-hdd/#findComment-11806944
its also a SATA 2 not SATA 3
My PC:
My Kids PC:
https://linustechtips.com/topic/977857-help-with-1tb-hdd/#findComment-11807128
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/977857-help-with-1tb-hdd/#findComment-11807466
