Cpu cooler unattached to cpu
2 minutes ago, SpyDaFX said:For everyone who asked about temps and hardware, im using an i7 8700k on z370-A pro motherboard with the air cooler antec C400 inside a sharkoon sgc1 window case with 5 fans.
Now about temps, im running when idle about 30 degrees and while 100% load 60 degrees, i tried a 2-3 hour long render session and it was 59-62 degrees max (cinema 4d) (i got those temps without turbo boost, stock speed)
i’ve been just wondering if the thermal paste could somehow leak into the cpu socket due to the heat idk my only concern is the safety of the cpu because i7 8700k is a pretty expensive cpu.
The thermal paste can't leak unless you used an excessive amount. The heat is fine with load temps of 60 Celsius, but the problem is that a fan is an object in motion, and you haven't secured it to anything. You need to do that ASAP before it jostles free.
