I have been working with a gaming laptop for the past several years. I am finally at the point where I can financially afford to put together a high end computer. My goal is to build a high end computer that will be about as future proof as possible. Outside of general use I will use this machine for gaming, professional photo editing, and coding. After a few weeks of planning I have come to the iteration below. I plan on running a custom hard line water cooling loop (CPU and GPU), hence the lack of a CPU cooler. Any input you all have would be greatly appreciated. Does anything seem out of place? Are there comparability issues I have missed? Does anything seem like absolute overkill? Again, I really want this system to stay as relevant as possible for the next several years. The only part that I am heavily concerned about is the GPU; but, the general consensus seems to be that a 1080ti, as opposed to a 2080ti, is going to be fine for quite some time. Any other comments, criticisms, etc... would be great. Thanks!
PCPartPicker
https://linustechtips.com/topic/976845-help-input-on-upcoming-build/
There's no such thing as future proof, but you do have longevity. Also, the consensus is 1080 ti as opposed to 2080, but the 2080 ti is another story entirely. Worth a buy if it's in budget, as it's the gaming king right now.
Primary PC:
PSU tier list
How many watts do I need?
That's more or less what I meant. I know you can't make a system that will never be outdated, I just want to make a system that will be able to last as long as possible before becoming outdated. Longevity is a much better word for my meaning.
1
I must have read some poor reviews then. I'll be honest, my gut has been telling me to go with a 2080ti and I would gladly pay the premium for a higher performance and longer lasting card, assuming that's the case. I do have two main concerns though.
  • I have no idea when I will be able to find a 2080ti as they appear to be sold out everywhere. I am somewhat worried about the US tariff changes raising prices me, but I admittedly do not know which companies this will effect.
  • To my knowledge, there are no water blocks currently on the market. That means I would either have to forgo building my loop right now, build separate loops for the CPU and GPU, or build a CPU loop that will then have to be modified to include the GPU at a later date. None of these options sound ideal or desirable, but maybe I'm mistaken in that sentiment. I have never built a hard line loop before, and I would ideally like to complete it in one go.
