My motherboard's chipset keeps overheating without any apparent reason and then the pc crashes . This happens within any timeframe ranging from 2minutes to half hour. They probability is highest when I'm using the PCI express (games or hd videos) . Tried both Linux and windows,and two different hard disk drives so they are immaterial . Please help
Motherboard Asus M5A78L-M usb 3
Processor FX 6300
Ram 8+8
Gfx0 MSI GTX 750Ti
PSU Corsair 550
https://linustechtips.com/topic/976775-overheating-chipset/
How's airflow inside your case? What fans are you using? Also, could you run a test like Aida64 so we can see your temperatures?
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11797348
just because the chipset heatsink is hot doesnt mean it is the cause of crashing. Games and video playback stresses the GPU and CPU too.
In fact, the lack of heatsink on the CPU VRM is more worrying. Try find a fan of some sort and blow it towards the CPU VRMs.
Desktop benching:
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11797371
Your PC is caked in dust, I bet airflow is awful. the downdraft from your CPU cooler should help stimulate some local airflow, so maybe it's time to remove your CPU cooler, clean it with some compressed air, and then replace the thermal paste.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11797484
I had this issue with my system where my CPU used to overheat for no apparent reason and the system used to shut down.
Later i found out that my CPU cooler mount was damaged and causing all of this issue.
Please check if your CPU cooler is properly attached to the CPU.
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11799307
Yes I have cleaned the processor and the heatsink and applied fresh thermal paste. it's still happening.
I'm awaiting isopropyl alcohol for cleaning it properly ,then I will update the status
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11800296
On 9/28/2018 at 12:53 PM, Shahrukhsk said:
Use HWMonitor to measure temperatures, you can get a better idea of what's going on
You can just use compressed air for dust
Primary PC:
PSU tier list
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11800300
1 minute ago, Shahrukhsk said:
It's not getting off with a blower ,sad to say.its gotten kinda sticky
Oh dear, maybe it's time to take some things apart and get a deep clean going. Maybe a good opportunity to clean the graphics card and replace the GPU thermal paste as well
Primary PC:
PSU tier list
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11800319
On 9/28/2018 at 1:03 PM, Shahrukhsk said:
As you can see,that's my temperature rise just while I'm observing the game.when I'm playing a game,the temperature goes through the roof,CPU fan starts sounding like a plane engine and it cuts off output .
With a max temp of 69 Celsius as "temp1" (whatever that is), hardly anything is even hot. None of your components are reaching thermal junction, so nothing should be malfunctioning. This doesn't seem like a thermal shutdown, more so some kind of software issue. Is it possible for you to replace the can on your CPU cooler? It's possible there's a CPU fan header reading issue, although I know that size fan isn't super common, so it may not be easy.
I did just notice that 4383 RPM though, that is quite a speed. Since the CPU cooler is trying its best to apparently keep the CPU temp under 60 Celsius, maybe there's something you can change in BIOS with the CPU clock speed. The fx 6300 is pretty hot, and seems like a lot to handle for that little aluminum cube of a cooler, so if you're overclocking it may be time to let off the hardware a little.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11800337
I cleaned the dust thoroughly with IP alc and tried blowing a portable fan towards the mobo,but isn't helping . Also,I never overclock any component as the maximum use of my pc is limited to entertainment,mostly movies and MOBA .
I should also mention,that I build this pc 2years ago. Is age an issue? And,if I get liquid cooling will it help?
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11805350
I think if you can get a graph of temperatures using something like aida64 it'll shed more light on the situation, because I don't see any thermal problems at all
Primary PC:
PSU tier list
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11805787
2 minutes ago, Shahrukhsk said:
Is this what your wanted?
That looks good. Since you aren't running into any thermal problem judging by that graph, there's a different issue
Primary PC:
PSU tier list
https://linustechtips.com/topic/976775-overheating-chipset/#findComment-11809319
