Hey,
Have a problem with my andriod phones its a note9 and s7. I have done the basics.. Disabeld battery saving, priority notificatons, app settings and even root with android lineage.
I wont get the notifications when the screen is black.. but when i unlock i get all at once.
https://linustechtips.com/topic/976631-help-notification-problem/
4 minutes ago, erik.ham said:
Hey,
Show notification on start screen is what you need to enable to show these messages.
Settings> Notification > app badges, and enable the show on start screen
Positive Mental Additude!
Just another Tired IT guy...
I have trippel check that now.. still have the same problem :(
  • From a Home screen, swipe up or down from the center of the display to access the apps screen. ...
  • Navigate: Settings > Lock screen and security.
  • From the Lock screen and always on display section, tap Notifications.
  • Tap the Notifications switch (upper-right) to turn on or off .
Different name on the S8+.. My Bad
Yea know what you mean for settings at the first reaply:) But still dosent work..
I'm just searching the web as well at this point, but some people reported the same issue:
If you go to Settings > Lock Screen and Security > Notifications > On > Hide Content > Off > Notification Icons Only > Off, this should add lock screen notifications to your device.
Good thing they have 3 different setting for the same thing on there xD
