Hi, so this is the first PC ive built and im not 100% sure what the temps etc should be. do these look ok? from all the videos and everything that ive seen this looks fine, (this is at idle) not 100% sure how to get the temps "under load" how do you do that lol
here is temps: https://gyazo.com/6cc80270d9bafbb5b8485f5b416c4a2e
https://linustechtips.com/topic/976575-temperature-question/
I usually use OCCT and Unigine Valley for stressing the cpu and gpu.
https://linustechtips.com/topic/976575-temperature-question/#findComment-11797749
