Suggestions for a CPU Cooler
Not really enough for a cooler that wont limit your overclock before voltage
Why a rebadged 8700k?
Desktop benching:
Probably because lower voltage is nicer
I can get away with 4.6 on my 212 Evo, so something nice like a cryorig H7 would be good
Primary PC:
PSU tier list
How many watts do I need?
How much volts did you use?
Desktop benching:
1.16 but I'm sure I can go even lower
Primary PC:
PSU tier list
You cant shove 1.35V Vcore and overclock that way with 212 Evo or H7 right? That's my point.
Desktop benching:
No you can't, but I'm not sure what your point helps illustrate then. Why would you do that, as opposed to using other people's overclock data and going for the lowest voltage at a given frequency possible (which is way easier with an 8086k)
Primary PC:
PSU tier list
To set a static voltage and go as high as possible in frequency.
Desktop benching:
I just did it the other way around. Set a static frequency and went as low as possible in voltage. There's effectively no difference.
Primary PC:
PSU tier list
It is different. Your target is to hit a clock speed you want with the least volts, which means frequency isnt the independent variable, voltage is. My way is to hit the highest frequency within the voltage limit, so voltage isnt the independent variable, frequency is.
Desktop benching:
Right, but in OP's case, given the budget for a CPU cooler, the 8086k can hit the same frequencies an 8700k can (for the most part anyway) for less voltage, which means thermal output being the limiting factor, the cooler CPU wins out.
Primary PC:
PSU tier list
I take a broader picture to the situation. Instead of the usually more expensive 8086k, why not spend less on the CPU (for an 8700k) and spend more on the cooler? That's why I have to ask whether OP's using an 8086k, bought an 8086k, or considering buying an 8086k.
Desktop benching:
I would say that OP could get a better cooler later and push the overclock even further, but I'll let OP answer if there's a better reason
Primary PC:
PSU tier list
Deepcool Gammax GT
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
Any shops you are using? Also list your case and RAM as those will limit selection. H5 or Dark Rock 3 (not pro) would be in that price range. I wouldn't pic budget ones, but thats up to you. Artic Freezer 33 eSports is rising star in budget cooler range.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Where are you shopping / located? What case and ram are you using?
