I know this might not be able to be answered easily but after watching the last live stream from linus he said there are some pretty smart guys here.
I just recently build a mini server
i5-3750
Asus P8Z77-i
8GB ram
120bg ssd/3TB hdd.
So I wanted to build a mini server and it works great but I want to be able to run one of my old pc's off of the virtual machine on my server. I am running Virtualbox and I have been trying to find a way to boot the pc to that virtual box and actually run the virtual box on my old pc.
I have been digging around the internet and found PXE booting but I am VERY new to the server side of things and a lot of it is way over my head. But it appears that I just need an os such as linux(which I am knowledgeable in) and have it boot directly to a vpn client. The problem is finding documentation on how to do it for free.
Like I said I do not know if this could be easily answered but it would be cool to do! I could run my duel core vaio with the performance of my i5.
https://linustechtips.com/topic/9762-virtual-machine-question/
If you're running VirtualBox, couldn't you just enable remote display and RDP into the VM?
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/9762-virtual-machine-question/#findComment-106187
Yeah i did install teamveiwer on it and it works fine but i was wondering if there is a way to boot directly into a RDP or vnc. Mainly to have an os wth as little resouarces as possible, like damnsmalllinux with only a vnc software on it and have it autoconnect to the vm.
https://linustechtips.com/topic/9762-virtual-machine-question/#findComment-106206
If you use any RDP software, you can go enable "remote display" in VirtualBox (Settings->Display->Remote Display), and using RDP software and the IP address, you can RDP into it.
http://www.brighthub.com/computing/windows-platform/articles/25914.aspx
15" MBP TB
https://linustechtips.com/topic/9762-virtual-machine-question/#findComment-106274
