Processor Cooling Corsair Hydro Series H60 120mm Liquid Cooling System - Standard 120mm Fan
Memory 1 ADATA XPG SPECTRIX D41 (RGB LED)
Video Card NVIDIA GeForce GTX 1080 ASUS Turbo 8GB
Motherboard GIGABYTE Z370XP SLI-- RGB Fusion, 3x PCIe x16, 2x USB 3.1 Gen2, 6x USB 3.1 Gen1
Power Supply 600 Watt - Thermaltake Smart Series - 80 PLUS Gold
Primary Hard Drive 240 GB WD Green SSD -- Read: 540MB/s, Write: 465MB/s - Single Drive
Data Hard Drive 1 TB Hard Drive -- 32MB Cache, 7200RPM, 6.0Gb/s - Single Drive
Also custom cables
Processor Intel® Core™ i7-8700K Processor (6x 3.70GHz/12MB L3 Cache) - Intel® Core™ i7-8700K
Handles No Handle
Looking at this IbuyPower  prebuilt I put the parts that i wanted in the rig and it is coming out to slightly cheaper with them then on newegg or even amazon wondering is this a good deal or should i just build my own with parts seen above !?
Also does anyone have exp with IbuyPower picking your own parts aside from their true prebuilt stuff?
https://linustechtips.com/topic/975772-pre-built-ibuypower/
If it's cheaper than if you build it yourself, go for it.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11787981
I wonder how can a system start up without a CPU.
Desktop benching:
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11787991
And that PC has all the buzz words - "Liquid Cooled", "RGB RAM", "Has an SSD", "Custom Cables".
It'll work, but it is a really strange configuration - Cheap AIO, Cheap SSD, Cheap HDD (like what TB HDD only has 32MB of cache these days?), and not amazing PSU.
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11787999
sorry wasent in the main part of the sheet to paste !
then it's a looks ++++++, value - - -, performance - - - build. I can make it cheaper and faster, just less bling.
Desktop benching:
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11788011
@Shipit
https://pcpartpicker.com/list/tkqFYT
Here you go. I took the processor down to an i5 but you can still overclock if you want. You really don't need an i7 if you are only gaming.
Quote
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($239.00 @ Amazon)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($90.99 @ Newegg)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($158.90 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($144.14 @ OutletPC)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($97.99 @ Amazon)
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($439.99 @ Newegg)
Case: Corsair - 750D ATX Full Tower Case  ($129.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($94.89 @ OutletPC)
Total: $1534.67
Generated by PCPartPicker 2018-09-25 01:44 EDT-0400
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11788064
Or some minor tweaking and you can happily have the i7 under $1600. FYI - you can get windows 10 for much cheaper than on the list below as well.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($369.99 @ Amazon)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-2666 Memory  ($125.98 @ Newegg)
Storage: Western Digital - Blue 500GB 2.5" Solid State Drive  ($80.99 @ Amazon)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  ($56.45 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 8GB DUKE OC Video Card  ($449.99 @ B&H)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($90.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.89 @ OutletPC)
Total: $1589.05
Generated by PCPartPicker 2018-09-25 07:07 EDT-0400
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11788610
On 9/25/2018 at 8:00 PM, IntMD said:
-snip-
I opted for the full tower because you only have 3mm of clearance left with a mid tower and that GPU. I never like to cram my expensive GPU in to the case, so I opted for a larger case because of the lengthy card. But, well played sir.
Edit: here's my build again with a smaller case and an i7. I checked the clearances on the case and the card and it seems to fit just fine.
https://pcpartpicker.com/list/yWQtNQ
https://linustechtips.com/topic/975772-pre-built-ibuypower/#findComment-11794799
