DT 990 Problem ?!
Go to solution Solved by dklhs90,
Yay i just noticed they sound way better now.
I guess burning in is actually not a gimmick ^^
Yeah the more you use them the better they get xD
Just plugged my brand new dt 990's into the e10.
Than listened to some music and it sounded muddy,not clear no highs really.
In games they were ok at pin pointing enemies but when i was walking myself or there was alot happening i couldnt hear anything because of the base.
E10 bass boost is off and i tried hooking the e10 in the back and in the front , nothing changed.
Running on low gain settings (volume:5) with a 3.5 jack.
Is this normal or is something wrong?
- Intel i7 3770|Noctua NH-D14 -Gigabyte GA-Z77X-UD3H -8GB Corsair Vengeance LP DDR3 -Evga Sc Signature 2 GTX 680 -Fractal Define R4 -2TB WD Black Caviar -120GB Samsung 840 Pro -Cosair TX 650Watt -Benq XL2420T -CM Storm Quickfire TK -Zowie Ec1 Evo -Fiio E10 -
Audio Technica Ath-AD700x
https://linustechtips.com/topic/97570-dt-990-problem/
Mmm. I own the DT990 Pro 250Ohm and DT990 Premium 600Ohm but unfortunately I do not own the E10. I do own an E11 but in your case i would check the EQ from the source first while keeping the AMP at default.
Or are your DT990 brand spanking new out of the box?
PC: The Oracle
Phone History: Nokia 3310, Samsung Z500, HTC Touch, iPhone 3GS + Samsung S5600 Preston, iPhone 3GS + Blackberry Bold 9700, Samsung Galaxy S + Blackberry Bold 9700, Samsung Galaxy S2 + Samsung Galaxy Tab + Blackberry Bold 9700, Samsung Galaxy S3 + Blackberry Torch 9800, Samsung Galaxy Note 2 + Blackberry Bold 9900 + Blackberry Playbook, Samsung Galaxy Note 2  + Nokia Lumia 920, Galaxy S4 +Nokia Lumia 920, Samsung Galaxy S4, Samsung Galaxy Note 3, Samsung Galaxy S5
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1304964
Ye i just got them.
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1304982
Ye i just got them.
Mmm then first try to let it work a bit so all the insides loosen up for the best sound quality
PC: The Oracle
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1304992
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1305005
PC: The Oracle
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1305008
it should be default but double check the sound properties to make sure all "enhancements" are disabled.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1306188
https://linustechtips.com/topic/97570-dt-990-problem/#findComment-1306209
