Hey Everyone!
I am looking to replace the stock fans that came with my AIO water cooler for noise purposes. When playing games and also when the system is under heavy load, the noise is still rather noticeable so I'm looking to find some affordable quiet fans with some RGB LED's.
I'm looking into swapping out my case for a "Thermaltake View 71 Tempered Glass RGB Edition". I currently have a NZXT Noctis 450.
As for budget, I don't have money to just throw everywhere but will happily pay more if it means quiet performance.
Essentially, I am looking for any recommendations on the best, silent (if possible) aftermarket 120mm fans.
Thanks for reading,
Jack.
https://linustechtips.com/topic/975471-quiet-case-fans/
What cooler are you using? Have you tried lowering fan speeds?
https://linustechtips.com/topic/975471-quiet-case-fans/#findComment-11797838
