So I already have a gtx 1060 and a 450w power supply. I want to upgrade because my motherboard is dying and I am tired of the fx 8350. Here are my two upgrades I have made, https://pcpartpicker.com/list/qVZm7W and https://pcpartpicker.com/list/4Xd76sWhich one is better. Should I get neither and upgrade with different parts? Also are those case fans good? What should I do? My budget is $530 max. I really would like to keep it lower than $530 though. It takes awhile to save money. I want to use it to edit videos and play games.
https://linustechtips.com/topic/975409-i-need-help-upgrading/
What 450W PSU?
Get a 2600 (no X)
a better cooler like the CoolerMaster Hyper 212 since the R5 2600 comes with just the Wraith Stealth
and the Asrock B450 Pro.
Save ~$60
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/975409-i-need-help-upgrading/#findComment-11785036
2 minutes ago, Hamface55 said:
My PSU is EVGA 450 BT 80+ bronze.
I'm not sure how I feel about that PSU.
You could use the $60 saved for a better one.
https://linustechtips.com/topic/975409-i-need-help-upgrading/#findComment-11785051
Just now, Hamface55 said:
Ok cool. Could I overclock the 2600 with the 450w or do I need more though?
I edited my post.
For some reason I had the EVGA supernova in mind...
https://linustechtips.com/topic/975409-i-need-help-upgrading/#findComment-11785054
8 minutes ago, Hamface55 said:
Oh gotcha. So what is a good powersupply I should get with overclocking in mind?
Anything from tier 3 up will do.
1 minute ago, Hamface55 said:
I think I will upgrade the PSU later. What do you think about this setup with this CPU cooler?
What CPU cooler? The Hyper212 Evo?
https://linustechtips.com/topic/975409-i-need-help-upgrading/#findComment-11785067
