Not sure what is causing it to freeze as it freezing at random times whether playing a game or while idling
I ran windows memory test all fine there
Pc specs
Don't think its overheating its currently got a CoolerMaster Hyper 212+ CPU Cooler
Not sure on how to test the cpu or motherboard or is there anything I should do?
Thanks
https://linustechtips.com/topic/97512-pc-freezing-randomly/
You should measure your load temps just to be sure.
Build 1: 4770k (H100i) | 2 x MSI 280X Gaming 3G | Asus ROG Maximus VI Hero | Corsair RM850 | 16GB Corsiar Vengeance 1600MHz | Corsair Obsidian 750D |
Build 2: 3770k (Titan Fenrir Evo) | Powercool 3GB HD7970 Asus Sabertooth Z77 | Corsair TX750 | 16GB Kingston HyperX Genesis 2133MHz Inwin Fanqua |
https://linustechtips.com/topic/97512-pc-freezing-randomly/#findComment-1304234
With RealTemp or do you recommend something else?
I just run MSI Aterburner for a few hours, It's the only thing I've ever used to check GPU temps but RealTemp should be fine to check your CPU.
https://linustechtips.com/topic/97512-pc-freezing-randomly/#findComment-1304263
