Choosing right cpu
Go to solution Solved by Streetguru,
11 minutes ago, cookiebeast99 said:
What monitor resolution/refresh rate?
If it's only 1080p 60hz you don't need a GTX 1080
Go for the ASrock Pro4 or MSI Tomahawk B450 boards, that one lacks a VRM heatsink.
So I have been saving up my money for a while now and under that time learning everything I could find about computer. And now I finally got the money for it but when I was sure what parts to buy I discussed it whit my dad I wasn't so sure anymore. He thinks that I should buy a 1tb m.2 ssd instead of a 2tb hard drive which cost much more. And  he pointed out that I might wanna switch my Ryzen 5 2600 to a intel processor. I will be using my computer for gaming, programming and web browsing and i won't be overclocking any part.
cpu: Ryzen 5 2600 whit included cooler.
Ram: Corsair vengeance lpx ddr4 2666mhz 16gb
MotherBoard: MSI B450M PRO-VDH
Gpu:MSI GeForce GTX 1080 ARMOR
Case: Corsair 280x
PSU: Corsair CX650M 650W
M.2 sdd: Kingston A1000 480GB
This is my current build, if you would change something what would you? And should I change the CPU?
//Greeting from Sweden
https://linustechtips.com/topic/974151-choosing-right-cpu/
No
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774391
I would not get an armor gpu because they have problems overheating, and, if you want a better gaming performance and dont plan on streaming, then an intel cpu would be better, but it doesn't really matter. A good intel processor for your budget would be an i5 8400, as well
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774396
While the R5 2600 is 'slower' than the i5 8400 in gaming it's still perfectly capable and since the OP's CPU is basically brand new it wouldn't make sense to something like this. In hindsight buying the i5 8400 at first would have been a better purchase.
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774408
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774421
I don't think the op has bought his parts yet:
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774439
@cookiebeast99 Also, you may wanna swap out the 1080 for a 1070 or something because it is quite pointless pairing a 1080 with a 2600, and the extra money could go towards faster ram, a better psu, or a better cpu
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774441
He says it's his current build.
زندگی از چراغ
https://linustechtips.com/topic/974151-choosing-right-cpu/#findComment-11774444
