I have been saving up for a while and decided it's time to buy an SSD and use it as a boot drive instead of my 6-year-old WD green.
I now have 4 options within my budget, a 480 GB Kingston A400, A 480 GB Team L5 Lite 3D, A 512 GB Gigabyte UD Pro or the tried and true Samsung 860 Evo but only at 250 GBs. I couldn't find much info on the first 3 but of course, the Samsung drive is infamous for its quality.
All 4 options cost about the same. I wouldn't mind a 250 GB drive as I will be using my hard drive as well but getting double the capacity at the same price is at least worth considering.
My Motherboard only has SATA 2 so I won't be surpassing 300 MB/s until a CPU upgrade is due. I'll only be using it as a boot drive and maybe put WoW on it but not much else. These are the only options I have available where I live and Amazon is not an option for many reasons. Thank you for your help in advance.
https://linustechtips.com/topic/974102-need-help-making-a-decision/
I'd get the A400, it's not the fastest but in my experience it's still a nice jump from a HDD. Use one in the Toaster, a 120gb, and I like it for what it costs
Builds:
