Have you ever looked at someone, and you both say "how's it going" at the same time...? And then you both just stare at each other, waiting for the other to tell you how it is going.. Both waiting for the other to break and give in and finally say how they're going. I hate that.
In the end, it was me. i said "pretty good, yourself?"
but i still hate that
https://linustechtips.com/topic/974084-hows-it-going/
-Thread locked-
Material is better suited as a status update.
https://linustechtips.com/topic/974084-hows-it-going/#findComment-11774260
Guest
