So i bought a gtx 1070 strix OC and was an upgrade from my gtx 970 so i clean install the drivers then i play euro truck sim 2 good fps then dips down to 30 fps stutter then goes back up and does it again after 3 mins then i changed a couple settings in control panel changed performance to prefer max then play the game again still does It lowered the settings still stuttered.Then i decided to play another game H1Z1 medium settings i was getting 40 to 30 fps like WTF!  I did not know what to do so contacted asus and there sending me a replacement gpu what you guys think what could cause it hopefully the replacment one is better at the moment i have my gtx 970 installed no problems in game bo stutter just lower fps in euro truck sim 2 thanks for reading.
MY SPECS
gtx 1070
I7700k ]
500 ssd 850 evo
8 ram 2400
500W be quiet 8 series 80 plus psu
https://linustechtips.com/topic/974013-issue-on-1070-strix/
Seems like it's throttling. Does your fans starts spinning really fast ?
What are your temps while playing ? It will be best to monitor them if it's going over 80C it will throttle.
Could be power limit too, stress test log would be good to see.
https://linustechtips.com/topic/974013-issue-on-1070-strix/#findComment-11773136
