I know...another OC'ing thread. I'll admit, I feel extremely stupid when it comes to overclocking. No matter how many videos I watch, I just feel like I am failing at it. I wish somebody can just do this for me as I'm stressing over it!
I also know that, nobody has to help me, but I would TRULY appreciate if someone could. I'm trying to get the most performance out of my system as I can. If anybody can help me out with my situation, that'd be amazing.
My Specs:
i7-6700k @ 4.5Ghz (Who knows if I even did this right?!)
Asus Maximus VIII Hero Alpha
Corsair Dominator Platinum 16GB 3000Mhz
EVGA 980Ti Hybrid SLI
Corsair RM1000i PSU
If I'm looking at this correctly, I believe my stock speeds for the Clock are 1304 and the Memory is 3505 (With Boost Clock [I think that's what it's called?]). I am also using EVGA Precision X. The only the I've changed so far is the Power and Temp target to max. I also downloaded Heaven, Valley, and MSI Kombustor Benchmark.
My first run on Heaven, without changing clock or memory offset was:
FPS: 71.3
Score: 1796
Min FPS: 29.9
Max FPS: 1385
Quality: Ultra, Tess. Extreme, AA x8
Resolution: 3440x140
At this point, I'm assuming working on the core clock first? I found 100Mhz to crash, so I dropped down to 80Mhz. The benchmark passed.
FPS: 73.1
Score: 1842
Min/Max FPS: 31 & 139.7
Now what do I do? Does this mean I found my stable core? Do i increase or decrease it still? What should I do now with the memory? I haven't touched voltage either, since I'm terrified of even touching that setting, should I be?
Any help or tips would be GREATLY appreciated. Thank you so much in advance.
https://linustechtips.com/topic/973874-overclocking-and-looking-for-help/
If it didn't crash, that is stable, yes. Don't increase, and decreasing is your option if the temp gets too high. Memory, idrk  too much about, but 3505 is fast speeds, so I wouldn't mess with it
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
