Just for clarification, you're looking for something such as a 5.25" bay expansion that supports USB 3.1 Gen 2?
https://linustechtips.com/topic/973780-usb-31-g2-cables/#findComment-11770978
Yes I have a connection directly on my MB and wanna use it. Or just a cable or even better yes a cool hub but I can't seem to find accessories in newegg or amazon if they are there I don't know where they are listed.
https://linustechtips.com/topic/973780-usb-31-g2-cables/#findComment-11771003
There's this one from Asus, although that uses SATA Express rather than USB as a header: https://www.asus.com/Motherboard-Accessory/USB-31-FRONT-PANEL/
You have the option to use it as an expansion card as well.
Apart from that, there doesn't appear to be very many options. Some cases have USB integrated into the front I/O, but I'm not aware of anything else that would be like what you're looking for.
https://linustechtips.com/topic/973780-usb-31-g2-cables/#findComment-11771015
