I need help with c++ and code blocks
Im trying to create a calculator that would calculate the area of a rooms floor and how much would it cost to replace it with a new one.
CurrentlyImtuck on line 7. What in the wourld is an initializer??? I need one before int in line 7.
1 //Price calculator
2 #include <iostream>
3 using namespace std;
4 int main ()
5
6 {int a,b
int S; // area of the rooms floor
double m2 price // price of 1 square meter of tiles
double Mamount // amount of money
10 cout << a * b << endl;
11  cout << "dial in the length of the room"; cin >> a;
12 cout << "dial in the widht of the room"; cin >> b;
13 cout << S = a * b;
14 cout << "the area of the rooms floor": << S << endl;
15 cout << "dial in the price of 1 square meter of tiles":;
16 cin >> m2 price;
17 Psuma = 1,05 * S * << m2 price >>;
18 cout << "the amount of money you need to pay": << Mamount << endl;
19 cout << "Calculation is complete" << endl;
 20 return 0;
https://linustechtips.com/topic/973706-i-need-help-with-c-and-code-blocks/
-Moved to Programming-
I would recommend using an IDE to help catch syntax errors, also you can use the code tool in this forum to show code in a more readable way
a la:
//Price calculator
#include <iostream>
int main ()
    int a,b
    cout << S = a * b;
    cin >> m2 price;
    return 0;
(note I didn't change any actual code, those issues @fpo mentioned are still there)
also, where is Psuma declared?
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
//Price calculator
#include <iostream>
int main ()
    int a,b // why integers for a,b and S??
    int S;
    double m2 price // you have to use an underline "_" to declare that variable, otherwise your compiler throws an error.
    double Mamount
    cout << a * b << endl; // not sure if you wanted to get this line printed, if so you have to use "".
    cout << S = a * b; // source of error. in this line you want to give out and assign at the same time.
    cout << "dial in the price of 1 square meter of tiles":; // here you have to use the : inside the ".
    cin >> m2 price;
    Psuma = 1,05 * S * << m2 price >>; //????
    return 0;
#include <iostream>
int main()
    double a,b,m2_price,Mamount,S; //double, if the room measurements are not whole numbers.
    cout << "a * b" << endl; //still not sure, if you realy want/need this line.
    cout << "dail in the length of the room" << endl; cin >> a;
    cout << "dail in the width of the room" << endl; cin >> b;
    S = a*b;
    cout << "the area of the rooms floor: " << S << endl;
    cout << "dail in the price of 1 sqare meter of tiles: " << endl; cin >> m2_price;
    Mamount = 1.05 * S * m2_price;
    cout << "the amount of money you need to pay: " << Mamount << endl;
    return 0;
