Laptops run toasty.
Post the actual temps and specs.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/973578-overheating/#findComment-11768851
What Bleedblue said. Laptops run hot, but depending on how high the actual numbers are can tell us if it's within acceptable realms or not
Download a programm called HWmonitor. That'll give you the temperatures and realtime specs on all your components.
https://linustechtips.com/topic/973578-overheating/#findComment-11768861
oooh yeah... O_O
https://linustechtips.com/topic/973578-overheating/#findComment-11768868
1 minute ago, TheSnowman37 said:
I've also realize that the cpu is at 100%. That has something to do with it right.
Well, yeah.
I wouldn't worry too much about My university had free tech support, if yours has too, you could take advantage of that to clear your mind of any worries.
https://linustechtips.com/topic/973578-overheating/#findComment-11768880
