Wait for it to come out to say for sure. If your CPU is bottlenecking though sure, you might want to upgrade. Otherwise I see no reason to
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/973549-upgrade-advice/#findComment-11768589
12 minutes ago, Kukuified said:
Hi LTT Community!
I need some advice on whether I should upgrade my i5-3570k to the new coming 9th gen processor. Mostly playing AAA games.
My current specs:
CPU:i5-3570k @ 4.5ghz
MOBO:ASUS Maximus V Formula
GPU: Gtx 1080
Monitor: BenQ 1080p @ 144hz
Thanks!
You might wanna wait a bit longer tbh, its not honorably slow yet... Its just not all that fast either. And if you do upgrade then just keep to an i7 unless money isnt an issue at all, then yeet it
https://linustechtips.com/topic/973549-upgrade-advice/#findComment-11768632
25 minutes ago, Kukuified said:
Probably but intel isn't releasing an 8700K replacement for the 9th gen, so you lose out on hyperthreading unless you pay for $499
Should just grab an R5 2600 on the cheap...
https://linustechtips.com/topic/973549-upgrade-advice/#findComment-11768638
10 hours ago, Kukuified said:
Hi LTT Community!
My current specs:
GPU: Gtx 1080
Thanks!
Might want to check this video out:
Might give you an idea on what you want to do. :)
CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti
https://linustechtips.com/topic/973549-upgrade-advice/#findComment-11770368
