What makes a decent substitute side panel for temporary use? I received an H700 and the side panel came shattered, seeing as I still need to use the machine inside of it between now and when the new panel arrives, what would be a good substitute for a panel until it gets here? The system is in a room prone to dust and pet hair so leaving it open for even a few days doesn't seem like the best idea with my limited experience in this. Thanks for any help
https://linustechtips.com/topic/973450-side-panel-substitution/
2 minutes ago, BadWithComputers said:
That was similar to my initial idea, then I thought I should ask here first ?
Now you know, not only you has stupid ideas, but remember, as long your stupid idea works, it ain't stupid
Quote me so I can reply <3
https://linustechtips.com/topic/973450-side-panel-substitution/#findComment-11767546
Absolutely do not wrap your PC in food packing foil if you get any static on your motherboard or if the foil touches your motherboard then it's gonna brick
https://linustechtips.com/topic/973450-side-panel-substitution/#findComment-11767554
