GTS 8800m Driver Problems
12 minutes ago, Lagercat said:
I know this is a old card and not many people will care about this but, i cant get any drivers to work on this card (in a old Gateway laptop) and when the drivers install i just get a grey screen. Anyone have ideas on how i can fix this thanks!
Whats the OS and what driver version? The GPU could be dead, and when engaged by the drivers crash.
Yours faithfully
These chips were quite unreliable. My guess is that it's toast.
Also, which driver did you try? The last compatible driver is 342.01 from 2016.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
