I have what in my opinion is a solid power supply. There isn't anything WRONG with it, its just my computer's temperature seem to be right on its fan threshold. What I mean by this, is that it powers the fan up and down. The corsair GS600W is designed to turn its fan off when its cool enough and spins it up when it isn't. But my pc seems to be at its temperature threshold. Its this cycle of powering up and down which is audible and in my entire pc, it kind of ruins the peace. I could make the whole hotter too keep it on, but this isn't really practical.
Any ideas?
"Lost in the woods, but DAMN these trees are cool!"
https://linustechtips.com/topic/97289-my-confused-power-supply/
How is the airflow in your case, and which way is the PSU orientated?
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1301678
Actually i heard about some corsair power supplies with the "not turning up fan thing up to 20% of usage" that they have wiered and not working fan profiles... I had to rma a 750hx because of the same issue and the new one worked. As far as i know the fan speed is not controlled by a temperature monitor, but by power usage, so adding or removing fans will not help. The fan does not turn on up to 20% usage of the rated power.
Another reason for the spinning up could be if you have a hazwell cpu. I think they have many bumps up and down in terms of power usage... you can switch the low power options off in the bios.
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1305426
http://www.corsair.com/gs600w.html
"An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature"
This only happens when I play games or use the graphics card which increases the power draw and increases the temperature too.
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1306132
Any ideas?
What are your specs?
Gaming rig- Cpu- Amd 9590, 16gbs of G Skill Ram, Gpu- GTX 760 windforce 3 edition 2gb. A Thermaltake water 2.0 water cooler for my cpu. Keyboard- Thermaltake Posieden , Case- 750D, Mobo Asus 990fx R2.0. 24 inch Dell LED monitor
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1307151
Still same thing with the hx series, the temperature of the power supplie is depending on the power that goes through. The actual fan rpm is regulated by the power usage.
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1308608
If it is power usage, would you say I'm pretty much stuck? I don't really want to throw in rubbish into my pc to make it more power hungry to keep the fan on. Reducing power would seem like an ideal option, but then the only way I can see this happening is if I BUY replacement parts that I don't really need or underclock things which isn't practical either.
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1311546
Actually you could switch off the power saving phases of the cpu in the bios and see weather that helps...
https://linustechtips.com/topic/97289-my-confused-power-supply/#findComment-1314791
