So, i have a I7 6700K And a EVGA SC 970.
On many games it seems i cannot get a constant 60 frames, even on medium settings? Is there a program i can use that can tell me what my PC is preforming like and i can post the results to you guys to help me out?
Im thinking of upgrading the GPU anyway, isit worth going to a 1080? Or for the extra money is the 1080Ti worth it?
https://linustechtips.com/topic/972663-pc-under-preforming-need-help/
You could try cinebench.
Not sure if that would help at all as I can't remember what that tests.
What are these for?
I found something wierd, im using MSI to overclock to try and help but it turns out when running the MSI Kombustor program only 323MHZ is being utilised?
https://gyazo.com/60a00451d2d7e37f1a9278a43def4880
But on the 3D program it says the GPU is at 99%?
Looked in task manager and the 3d setting withing my GPU is at 99% Is this normal?
https://gyazo.com/55d355c74a73ae88766b38fb2e006a80
ether a bad video driver install..... which can be a nightmare to deal with or the card has gone bad.
MSI x399 sli plus  | AMD threardripper 2990wx all core 3ghz lock |Thermaltake flow ring 360 | EVGA 2080, Zotac 2080 |Gskill Ripjaws 128GB 3200 MHz | Corsair RM1200i |200tb raw | Asus tuff gaming mid tower| 10gb NIC
On 17/09/2018 at 10:50 AM, dgsddfgdfhgs said:
usually 3 years, 5 for zotac only I believe .
I have a 970 too, but never see you mention games resolutions / temps etc
does msi afterburner shows its usage?
Usually im trying to run ultra or high graphics at 1080P
:) hey I have the same issue.... But i have a laptop with a 1060 max Q.  There were a view things what i tried so far what helped me but did not solve the issue.
1. Go to Nvidea drivers  >  turn of Vsync, for some odd reason this effects the computer even if you already turned it of in the game..
2. Disable Wispermode in the nvidea settings. ( maybe this is for laptops only? )
3.  Disable the Intel speedstep in the bios, boot into windows. Then reboot and turn it back off..
That being said  :) it did not solve the issue. But it did impact performance in some way.  I will post a screenshot in a bit.
edit: https://www.3dmark.com/3dm/28762707
