HELP
Go to solution Solved by 3 Lions,
Just now, staroutahell said:
win 10 32-bit
This is causing your problem, the 32-bit version will only read 4GB.
Your post is very vague..  what OS are you using, what are your system specs?
https://linustechtips.com/topic/972514-help/#findComment-11758432
1 minute ago, staroutahell said:
i have 8gbs of  ram but me system says i can only use 3.6gb ram and the rest is for the system iv tryed msconfig but it just keeps going back help plz
You have 8Gb of RAM and 5Gb of that is being used by apps.
The 3Gb is all that's doing nothing at the moment.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/972514-help/#findComment-11758433
win 10 32-bit
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/972514-help/#findComment-11758439
