Compatibility and Performance Questions
Solved by Electronics Wizardy,
Just now, 1988fido said:
how do you know they work together?
the SFP DAC cable
or the transceiver module
in my research there are many types and some are not compatible with other stuff
so that nas have sfp+ port on it but how you know which cable will work with it?
i found that there is different sizes wave lengths etc.. but couldn't understand
umm also is there a similar bundle or option in amazon ?
thanks for the help . you been very awesome and fast reply
Thats a direct attache copper cable, you just connect one end to your pc and the other to the nas.
Ebay is your friend here.
