So my pc worked perfectly for 7 months then it suddenly broke while playing.
It wont post with my ryzen 3 1200 but it works perfectly with ryzen 5 1500x.
I tried every bios update, CMOS reset but it won't post.
Tried my ryzen 3 1200 with an other motherboard and it works so i don't know what seems to be the problem.
Specs:
CPU: Ryzen 3 1200
GPU: Geforce GTX 1060 6GB
PSU:Seasonic 520 w
RAM: Kingston Hyperx Predator 2x4 GB
MB: Gigabyte AB350 Gaming
https://linustechtips.com/topic/972273-ryzen-3-1200-wont-post/
26 minutes ago, waaarrd said:
Your PC is haunted
Maybe try switching up the RAM, different slots or just one stick at a time
https://linustechtips.com/topic/972273-ryzen-3-1200-wont-post/#findComment-11756273
Specs:
CPU: Ryzen 3 1200
PSU:Seasonic 520 w
I want to say that it seems like a motherboard issue, but your 1500X worked fine.
I also want to say that it seems like a CPU issue, but your 1200 worked fine in another motherboard.
I'm assuming the 1500X and "other motherboard" aren't yours. Try switching up the RAM, replacing the battery, and whatever else you think might help. If nothing, replace one or the other.
P.S, if you decide to get a new CPU, Ryzen 5 1600 is ~$150, about the price of 1500X.
https://linustechtips.com/topic/972273-ryzen-3-1200-wont-post/#findComment-11756289
