Thanks for posting your computers specs. With that set up... It'll probably be hard to run anything no matter what you put in there, given the age of the Q6600. A 1050 Ti is still likely to help out some in lower demanding games though.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/972137-will-it-bottleneck/#findComment-11755118
i just wanna have a lil bit better computer because there are some games i really wanna play but with 650 i cant, and problem with my 650 ti boost is i can't for some reason upgrade drivers but is should...
https://linustechtips.com/topic/972137-will-it-bottleneck/#findComment-11755121
even after adding a 1050ti, your RAM will still bottleneck you, with CPU following closely. Lastly, that power supply is too risky for a the cost of a 1050ti
Desktop benching:
https://linustechtips.com/topic/972137-will-it-bottleneck/#findComment-11755160
38 minutes ago, Matej420 said:
so i have shit computer. i wanna upgrade GPU but i don't know will it bottleneck. my spec: CPU - Intel Core2 Quad Q6600 2.4 GHz, GPU - gtx 650 ti boost (i wanna upgrade it to gtx 1050 ti), RAM - 4gb DDR3, PSU - some shit with 400W, HDD - Toshiba 2tb, 7200 rpm. plz help
Ok, so how much can you spend on ur PC?
Also, where r u located?
https://linustechtips.com/topic/972137-will-it-bottleneck/#findComment-11755164
to be honest a spend a little money on that. about 200 euros because my dad worked on that compuer and it was from company he worked but it colapsed and bougt it for cheap price. I am from Croatia
https://linustechtips.com/topic/972137-will-it-bottleneck/#findComment-11755172
Get an additional 4gb ram
Upgrade ur psu to something better like Corsair cxm or cooler master masterwatt
Get a cheapo cooler like cryorig h7 ND overclock that sucker. With a tape mod, that cpu can be OC past 3ghz easily. Google about it.
Get a 1050ti. Bottleneck will be there. But u'll be able to play games at 60fps 1080p at tweaked settings.
Also, if u wanna make ur overall system a bit faster, then slap in any cheapo 120gb SSD, ND u'll notice the difference that an SSD makes in a system.
https://linustechtips.com/topic/972137-will-it-bottleneck/#findComment-11755251
