Top Case Fans
Solved by jiyeon,
Prioritise a rear exhaust fan first since generally case fair flow is from front to back.
For top case fans, those are worth it when you laready have established front and rear fans. I have a single 120mm case fan set to exhaust hot air from the inside of the case, since hot air rises and I want to optimise it as much as I can.
toxic_worper ·
Posted in New Builds and Planning8 -
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
