So I have a 1080ti connected to display 1 via DP and connected to display 2 via HDMI. The audio normally works but I've noticed for some reason it just goes away and eventually comes back. However, it never cuts out as it's working. For instance today I was on youtube, the video played fine, clicked another video and no audio at all. I can ALWAYS use my blu tooth headphones and get audio which made me think it was a problem with both cables (unlikely as the chance of 2 cables failing at the same time is low). I tried different cables and tried unplugging them and putting them back in, nothing. Tried restarting my pc and nothing. Tried unplugging the PC and nothing. I went into my audio settings on the nvidia control panel as well as my audio settings on windows 10, nothing. Tried reinstalling my GPU drivers, nothing. Tried doing a clean install of the drivers, nothing.
To be clear it's not a browser problem, firefox, tor and edge all do not play audio, neither do any applications.
Anyone have ANY ideas? I doubt it's a hardware problem but I can't find out whats wrong with the software.
https://linustechtips.com/topic/971631-pc-audio-problems/
Just to clarify, you're running the audio through one of the displays?
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
https://linustechtips.com/topic/971631-pc-audio-problems/#findComment-11750591
9 hours ago, zacattack1996 said:
Yes, and I've tried both to make sure it isn't bad speakers.
May I ask why you aren't using the on-board audio of the PC as opposed to display pass through?
https://linustechtips.com/topic/971631-pc-audio-problems/#findComment-11752965
I use a little program called Audioswitch to swap between my speakers and headphones. It sits in the taskbar and lets you see where the audio is being directed between all your sources. I'd recommend downloading it and seeing if your audio device is just being switched for some reason.
I mean, you can do without it, but it's more of a hassle, Audioswitch is much quicker.
Unfortunately, that'll only tell you if Windows is switching sources or not, and not the reason behind it, but it's a step I guess.
#Muricaparrotgang
https://linustechtips.com/topic/971631-pc-audio-problems/#findComment-11753536
What's display pass through? I'm using my gpu as opposed to onboard graphics so I thought it would also mean I'm not using onboard audio?
https://linustechtips.com/topic/971631-pc-audio-problems/#findComment-11754080
You can use any audio device in conjunction with any video device.
Are you using headphones or speakers? What are they plugged into?
https://linustechtips.com/topic/971631-pc-audio-problems/#findComment-11754138
