Here is my setup:
Hi, firstly here is my setup:
CPU: Intel i5-8600k
MOTHERBOARD: GIGABYTE Z370P D3 LGA 1151
GPU: NVIDIA GTX 1060 3GB MINI ITX
RAM: 16GB DDR4 Ram 2400mhz
Storage: 256GB SSD
1TB HDD
500GB SSD
Operating System: Windows 10 Home
Power supply: EVGA SuperNOVA 650 G2 650W Power Supply
Question is will I be able to overclock my ram to 3000mhz at 1.35v and run stable??? Just need a general answer
https://linustechtips.com/topic/971426-overclocking-help-with-ram/
There is no general answer except "it depends on your module".
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
Is this kit rated to do that from the factory?
Desktop benching:
3 minutes ago, Famalam said:
Ya apparently it has good cooling
then just enable XMP profile and you're good
7 minutes ago, airdeano said:
prolly not as those kits are binned in a lower domain and 2800 would be a stretch at 1.45v not 1.35v.
your mobo VRM won't like you too much punching high-voltages and has a thin margin of error.
not sure why VRMs are related in terms of overclocking memory. All motherboards (excluding prebuilts) overbuild memory VRMs because they simply reuse components on the Vcore.
Desktop benching:
I am running from 2400mhz 1.2v to 2666mhz to 1.25 v.
Do you think I will be fine??
Here is my ram:
https://www.amazon.com/ADATA-2400MHz-Memory-Modules-AX4U2400W4G16-DRZ/dp/B06XYSSS5C?th=1
Also here is the guide I followed:
https://www.kitguru.net/components/memory/luke-hill/adata-xpg-z1-16gb-2400mhz-ddr4-memory-kit-review/all/1/
Here is my ram:
Then it's NOT rated to do this...
You can try though. Dont use BCLK like Kitguru did, just crank the memory multiplier. Btw setting DDR4-2933 rather than the default DDR4-2400 is already cranking up the memory multiplier.
Voltage wise, this stick should easily handle 1.35v
Desktop benching:
CL16 at 2400MHz gives little room for OC to 3000MHz especially if it isn't Samsung B-die. Even if you manage to get it to 3000MHz at CL18 or CL19 the trade-off in the loosened timings are not worth it just to get 600MHz more out of your RAM.
Personally, I have a 4400MHz CL19 rated kit and I have use 1.4V to hit a stable daily of 4000MHz CL16. That doesn't mean you can't try though, tightening the timings or a little bit more clock speed is always good. You can use stressapptest to verify the stability of your memory.
For using stressapptest:
- Download Linux Mint here -https://linuxmint.com/download.php
- Format utility (ISO to USB) - rufus (open sourced) -https://rufus.akeo.ie
Use the format utility to get a copy of linux mint on your thumb drive.
Getting google stressapptest:
- Open terminal
- "sudo apt-get install stressapptest"
- 1 hour stressapptest with settings recommended by Raja@Asus-> "stressapptest -M 14500 -W -s 3600"
Up to 1.5V Dram should be safe for daily use but beyond that is not recommended.
Im stable perfectly at 2666mhz with 1.3v and its been running good
Also dip the timings if possible
Desktop benching:
