Hey all,
Looking to purchase an air cooler and start up some overclockling on my rig. Definitely not looking to build a custom loop, and kind of apprehensive about have having any water cooling in the computer. I'm essentially looking for any suggestions of high-end air cooling that could fit inside 20cm wide case. This would be for an i7-6700k on a Z170 board btw.
Also, got my eye on three coolers in a shop near my place: the Cooler Master Hyper 212 Led, the Arctic Freezer I30 (both air coolers), and the Kuhler H2O K120 (AiO water-cooler). Any proposals/suggestions for a starting overclocker?
Thx all
https://linustechtips.com/topic/971420-help-on-cpu-cooler-choice/
20cm wide case doesnt relate to how tall of a CPU cooler it can hold. We still dont know what to recommend.
too weak for reasonable overclocking.
Kuhler H2O K120
wont out perform the big air coolers, still worth considering if its cheap
Desktop benching:
What case are you using?
Where are you shopping / located? Budget?
